Clear Corners
Clear Corners
I wanna clear the corners on my '96 ES, but am afraid I will get condensation in them. Has anyone who has cleared the corners had any problems?
Make sure you heat them up well when you put them back together, and run a bead of black silicon or something along the edge to make sure they are sealed. If you do those things, you should be OK. I had some condensation in one of mine after doing it, but took it out and resealed it, no problems since.
Cool... thanks for your input. I will go ahead and try it. I guess the worst that can happen is I will have to redo it.
1loadlex: You took the orange out of your taillights? How does that look? Do you have any pic?
Thanks again..
Thanks again..
mine worked well, and i didnt use silicon, mine were messed up and foggy before i did the mod, but after they were tight. i left them in the last time with the screws in and reconnected for 10 minutes so that it was completely sealed. it worked well. its tight
Chicago Lexus Club Moderator
I'll put ups pics later today!!!
I just got, or i should say my Parents just got, a new digital camera finally. I will take pics today. They will be up around 7 p.m. or so.
Adam " Lexist "
Adam " Lexist "
