ES 300 Projection Fog Lights Conversion
Does anyone know if you can change from the reflective fog from 95-96 to the projector ones on the earlier models?
And does anyone know why my pic isn't working?
The '96 fogs are set rectangular openings in that black lower grille. So, if you replaced your '96 lower grille with a 92-94 lower grille with the round openings for the fogs, it will probably work. I assume the wiring harness runs at the same wattage, etc. for both types. Perhaps you could find a junked 92-94 that was hit in the rear or side, and still has the front intact.
I would if I was sure it would work. I wonder if the mounting brackets are the same. Does anyone have easy access to both to compare the mounting areas for the fogs and the lower grill? Well, another complication for me is that the screws that hold one of my fogs in are broken off in the brackets and I haven't been able to get them out. The fog light is holding in place well with tie straps, but I don't know how a square one would work if I switched.
hey guys...my dad has a 96 and i have a 94 so i looked at both of them for ya guys and i found out that they were exactly the same.... the grills seem to be attatched and fitted the same too...i was also interested in converting my fogs to the 95-96 style.....so amrit50...I am casually interested in trading but not quite sure....
![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
Just wondering.....Why do you like the projection fog lights, IMO the rectangle ones look kind of "newer".... I guess I like newer looks since I am jealous of newer lex'z...hehe
