ES 300 Headlights
Old 09-11-02, 04:27 PM
Seattle ES300
Seattle ES300's Avatar
Originally posted by serrano007
Can you get that Meguiar's stuff at Kmart? I can't find it anywhere..
My headlights are HELLA dirty... You think it will get rid of this?
Mine were worse. I just noticed that your internal lens (the little round ones inside the casing) are quite clear looking. Mine almost have a frosted look to them. Is that normal? If not, how do I clean them?
Old 09-11-02, 05:12 PM
meZoom!
Super Moderator
meZoom!'s Avatar
Seattle ES300 and others... i have noticed while driving around town that a select few number of our generation ES's have really shiny chrom-ish looking projector housings inside the sealed headlight casing. you know, the round metallic parts. the one in the picture shown above and i believe EGainer's ES is the more shiny kind. mine is not so shiny. I don't know if they were made different, or well maintained (how do you polish the inside of a headlight?) or what. it kind of seems like it is regardless of the model year, cuz i see some shiny 92-94, and the others are not shiny 92-94. which come to think of it doesnt make much sense. call me crazy what not, those are my observations. if anyone else has noticed this, please reassure me that i am not "seeing things." and btw, i dont think i have seen any shiny kind in year 95-96.
Old 09-11-02, 07:47 PM
juan01
juan01's Avatar
Hey Seattle, think you can send me a bottle of that Meguiar's stuff? I can't seem to find it anywhere here on Guam.. I'll send you a money order? Just let me know if you would consider it..
zoom, mine is a 1996.
amrit50
amrit50's Avatar
I have a 96 and I guess they are 'shiney' So, I dunno what's up.
When I did my clears, and the headlight assy was open, I noticed that the projectors in one side had a haze on them. I wiped them down w/ a paper towel and now they look great! So, you should do the clear corner mod and wipe down your lenses.
Old 09-11-02, 11:43 PM
Seattle ES300
Does someone have a template to take the headlight housing out?
Old 09-11-02, 11:47 PM
Seattle ES300
I can do it if you want. Have you tried online ordering? Here are some links:
http://www.superiorcarcare.net/megplascar.html
http://www.meguiars.com/
Let me know. BTW, I bought the #17.
Old 09-12-02, 12:11 AM
amrit50
amrit50's Avatar
Check this out:
http://hometown.aol.com/seanmcelligott/index.html
Old 09-12-02, 02:25 AM
Seattle ES300
Check this out:
Thanks. Now all I have to do is wait for my wife to go out of town so I can get away with ripping her car apart.
Old 09-12-02, 02:44 AM
amrit50
amrit50's Avatar
be careful and take your time. I modified those instuctions. Here's what I did:
Cook it for about 5 min on 250, then dig a flathead screwdriver into the black goo to separate the 2 lips. the outer lip is on top of the inner lip. So run your screwdriver (horizontally) down the seam. Do the entire top. Put it back in the oven for 5 min and run it down the bottom seam. Have a friend help you, and just pull it appart. If it starts to budge but it's too hard, back in the oven. It took me 15 min. to get it apart. Go and buy some of that black silicon sealent. When you wanna get it back together, put this stuff around the entire lens, then back in the oven for 5 min. Put it back together, and clamp it closed. I used bungee chords. Any 2 clamps will do. Once you have it clamped, back in the oven for about 5 more min. THen once you take it out, more sealant on the outside. Entire process takes an hour. Good luck. Send any questions.
Old 09-12-02, 06:40 AM
juan01
juan01's Avatar
Thanks for the URL's, I think I will order instead.. So you won't have to deal with anything.
Old 09-12-02, 05:13 PM
EGainer
EGainer's Avatar
the reason they aren't shiny... the 95 and 96 es have black tinted "chrome" on the inside, not just "chrome" like the 92-96
Old 09-12-02, 09:41 PM
blux
blux's Avatar
wha? I am confused....the headlights are all the same IMO, theres just somes lines on the 95-96
Old 09-12-02, 09:50 PM
EGainer
EGainer's Avatar
they aren't
Old 09-12-02, 09:57 PM
EGainer
EGainer's Avatar
95 - 96 darkened headlights
Old 09-12-02, 09:59 PM
EGainer
EGainer's Avatar
this is why, whenever a 95 - 96 clears the corners, where the corners are not darkened, they notice that their corners seem brighter than the rest of the headlight....
Quick Reply: ES 300 Headlights
