LED DRL Parts List
Just want to make sure I have everything I need in order to convert the DRL's to LED.
http://www.v-leds.com/Exterior-LED-B...60696-1-2.html
http://www.v-leds.com/Exterior-HID-H...32086-1-2.html
http://www.v-leds.com/Exterior-LED-B...91005-1-2.html
They have 2 different kinds of DRL's, don't know if you have to get the more powerful ones
http://www.v-leds.com/Exterior-LED-B...62651-1-2.html
Yeah I saw those, but would rather go with the less bright ones actually. Is that everything needed though? I'm sure I could give V-LED's a call on Tuesday, I was just trying to bypass that.
Why do you want the less bright ones that require the module/harness. The new 13w ones are the best for 10 bucks more and don't require anything.
The only reason I can think that you'd want the less bright ones is so you can still see the inside of the housing and not that blinding glare. But to be honest in the day time and dusk that's how the new ones are. It's only at night that they seem glaringly bright. Even then the camera makes it worse.
Both of those DRL LED's require modules (boosters), since regular DRL bulbs run at half voltage and u want to run LED DRL's at full voltage (13V).
VLED's states that if u run those high power LED bulbs, u need to get the harness. So yeah, i would get those 3 things (bulbs, module, harness).
