Popped in Silverstar Sylvania's
After I changed out my fogs to a whiter bulb, my halogen headlights looked so yellow and so dim. I decided to get some Silverstar Sylvania's @ $25 a piece at a local Autozone. I decided just to keep these in here until I can afford the 6000k kit. Looks just like 4100k after they warm up and turn white. Very impressed. Doesn't have the cheap ricer look at all.
Highly recommended for those who can't afford the HID kit just yet.
I'll take some pictures at night to show you guys how it looks. Hard finding good lighting in the daytime to show off the lights. I'll also take pics of the spread.
Brendan - I also have had these bulbs for a few months. I like the nice clean white look, and the $$$$ is great too. Got the idea from TXSTYLE's post a while ago.
My suggestion: try a set of white led's for your wedge bulbs. They have more of a purplish/white look to them, plus they are generally more reliable than conventional bulbs. Mine look great...kinda like having HID wedge
Eric
Eric
I got them for my hi beam and i am very pleased
also got them for my wife's RX300 which sits much higher and it lights up soooo much its wonderful i can see far ahead.
Erick G
Erick G
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
Those look nice!! do you know if they have any H3's?, I have been trying to get some for my foglights and havent been able to get them at the autoshops around here, not even Autozone.. If you happen to find some, let me know , I can pay you at the next meeting!!
Brendan, lookin' good.
Question for all: I believe the 2000 I have has a different DRL / high beam setup than the '98s (and '99s?). So to brighten the DRLs I just change out the separate wedge, right? What do I change that to?
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Only available in 9004/5/6/7
http://www.sylvania.com/auto/silverstar.htm
bit the DRLs are the 9005 high beam bulb.... they are not the wedge bulbs unfortuantly so even with blue high beam bulbs (less light output too) they will still be yellow because of the low wattage of DRL.. my suggestion is you disable DRL, figure out how to make ur fogs as DRL, or have ur lights on all the time.. good luck man!
Originally posted by Aristo V300VE
Did you clear out your fog lights or do they come stock like that? All the car I have seen like mine have a yellow plastic cover over the bulb
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
