HID retrofit drivers light won't come on
I did the HID retrofit 5 years ago and it has worked perfectly. Recently however the driver's side light will not come on. I have moved the bulb and ballast to the passenger side and it works perfectly. I moved it back to drivers side and it will not work. I have checked the relay, all grounds, all fuses, all wiring connections (I have power going to the ballast) and it still won't work. I've searched all the threads and tried everything but can't get it to work. Anyone have any suggestions?
