Yellowing HID Light (one side only)
I have a set of HIDs on my 06 IS350. I don't remember the brand but I have had these without issues for the past 5 years.
Just today, I noticed that one of the lights is yellow (the other side is fine - normal pure white color).
Can anyone provide some advice on what could be the issue? What part may be failing?
Former Sponsor
I would suggest swapping your bulbs left to right to see if the problem carries over. It sounds like the bulb may be going but the question is whether it is going as a result of a bad ballast. If it is the bulb I would suggest getting a set of HID bulbs otherwise your bulbs will not match in color.
Steve
Steve
Thanks Steve. It looks like the bulb that was going yellow is now dead. I will try to switch the bulbs to see if it's just an issue with the bulbs.
If it's just the bulb, can I buy any set that is compatible with my car? Meaning, can I keep my ballast (not sure what brand it is) and just replace the bulb?
