headlight help
Old 10-05-02, 05:47 PM
mcelligott
mcelligott's Avatar
No clips on mine -- 92
Old 10-05-02, 09:57 PM
dariusman19
dariusman19's Avatar
Nope no clip on my 94, but if there was then the reason why I didn't mention it was because it's so easy to take them out a 1st grader can do it!:eek: and I just forgot.
Old 10-05-02, 10:10 PM
EGainer
EGainer's Avatar
sorry, they aren't clips, they are a form of holding device behind the division between the turn signal and the headlight. they are on the 94, i dont know about sean's, but they are on the 94. and they were on my 93 as well
Old 10-08-02, 04:51 PM
fog80
fog80's Avatar
Originally posted by EGainer
i reposted the old thread i started a while ago so that you could see how to do it... check the headlight tutorial thread. i know that some people said if you can't get the headlight out, then you shouldn't do the clear corner mod, but remember, i posted how to get the headlight out a long time ago. so other people have used this and got the headlight out wtih some help. there's no problem in that, it's not difficult. and this is what CL is for
oh yeah, it's not just 3 screws. you forgot the clip, unless you have already broken that without knowing it was there.... in that case, then all you have is 3 screws...
sean, you forgot the clip too
where can i find this thread?
and once i take that splashguard off how do i get the lil black clips to hold again?
Old 10-08-02, 05:06 PM
EGainer
EGainer's Avatar
i just recently reposted it, it was started by me. called clear corners tutorial...
Old 10-08-02, 08:46 PM
fog80
fog80's Avatar
thanks
Old 10-10-02, 02:55 AM
Seattle ES300
Seattle ES300's Avatar
I'm gonna try this mod. Just did it on my CL...where I had to remove the entire front bumper first to get to the screws holding the housings. If I can do THAT, then anyone can get the ES housings out w/o a problem.
Old 11-22-02, 01:18 PM
fog80
fog80's Avatar
im bout to open it up.
im just making sure i got all the things i need to clean my headlights cause they are worse than any picture ive seen on here.
Senior
RX - 1st Gen (1999-2003)
02-22-14 02:15 PM
kevin.tran
12-23-06 11:29 AM
ILOVEGIRLS
Lighting
42
05-26-06 12:58 PM
flm
03-13-02 09:33 PM
Quick Reply: headlight help
