Yellow fogs on my ES 300
Yellow Fogs... Yes I want Yellow...~
I have a friend that drives a GS400 and i notice that his fogs is yellow... really yellow like the ones on the IS300... I know that the IS300's fog is yellow only because of the front lens... but my friend's GS400 has clear fog lens but the lights are really yellow... Anyone know if those bulbs will fit the 1998 ES300?? I really want yellow fog lights... sick of seeing all those other ppl that have White fogs... want to be different...
Thanks...
Thanks...
i have yellow fog lights...hehehehe..and yes, it's exactly clear lense with that yellow lights.
i believe it doesn't fit to your car..
ps>you can just chage the bulbs but you have search a little to find the right yellow color you are looking for.
[i]J/K, another reason why the first generation ES300 rules muahahaha... [/B]
Those yellow lights was one of the main reasons I didn't want to get rid of my '94.
If you happen to find the right lights, HOOK ME UP. I've wanted those for years.
The foglight bulbs on the '98 ES300 are of size H3; subsequently, '97 and '99 may be the same (information in owner's manual). AFAIK, only PIAA makes a ionic yellow H3 bulb, which you can do a search to find them.
Luc
Luc
thats sounds like agood idea . I was thinkning of changing my bulbs anyway cause they are weak . Here is a link for the yellow h3 bulbs
http://www.piaa.com/h3bulbs.html
Luc
Luc
Originally posted by 1SICKLEX
That is cause the GS bulb is actually a regular 9006 bulb and the glass is green. SOme people have put green film over the fog light to give it the green look.
Where can I get film??? Is it ok to just use permanent marker over the bulb, it's 35 watt so it doesn't burn as hot as the headlights?
