Just installed Volt HID...now what?
Old 04-19-12, 06:03 PM
reyoasian
reyoasian's Avatar
Default Just installed Volt HID...now what?
Just installed Volt 6000K for my low beam (09 IS)
Now the lowbeam looks great, but my fog and drl are still halogen and I don't like the colour.
I am thinking of changing fog to projector led
As for the DRL, I want to do the same but there's 2 issues:
1) regular DRL is 9v? LED is 12v? So will I need a relay?
2) I think DRL and HiBeam on the 2IS are same light, so what's a bulb that will work both as DRL and as HiBeam?
Thanks in advance!
Old 04-19-12, 06:04 PM
langjaykev
langjaykev's Avatar
buy another hid kit for the fogs , and buy some DRL LEDs off VLEds!
Old 04-19-12, 07:42 PM
reyoasian
reyoasian's Avatar
Not going to install HID for the fogs.
VLeds is going to be quite expensive after shipping and duty. But my real question is that is there a led bulb that can work both as DRL and as HiBeam?
Old 04-20-12, 08:17 AM
ANCL
ANCL's Avatar
No LED can reproduce the high beams that halogens DRL can produce.
If you ever find it, let me know.
Old 04-20-12, 06:45 PM
reyoasian
reyoasian's Avatar
So I guess forget about high beams? Just LED the fogs and DRL?
Old 05-01-12, 09:55 AM
03pcoupe
03pcoupe's Avatar
Leds in the fogs wont produce as much usuable light as the stock bulbs, but if youre just going for looks then leds will be alright... You could go with HIDs in the fogs? That would give you the HID-matching look you want as well as more usuable light.
Old 05-01-12, 11:51 AM
Toxicxk23
Toxicxk23's Avatar
I'm a little confused. So the DRL and High beam is the same exact bulb? If I change it to an LED, it basically means I won't have a usable high beam? Is the stock DRL bulb a halogen?
Old 05-05-12, 12:10 AM
03pcoupe
03pcoupe's Avatar
Yes, yes and yes. DRL/Highbeam are the same. You lose high beam function when you use LEDs. And the stock bulb is a halogen. You can either have the cool white DRL with no highbeam or ugly yellow DRL with highbeam... Sucks but its the only way right now.
IamLexus
11-16-16 10:43 AM
jimjaix
06-22-13 05:39 AM
reyoasian
04-16-12 05:25 AM
Huynh9999
RX - 3rd Gen (2010-2015)
13
03-10-12 08:32 PM
L-S-D
12-09-09 01:34 PM
Quick Reply: Just installed Volt HID...now what?
