Day time runnings
I believe is this what most people are using right now... You lose your highbeam function with these though
http://store.ijdmtoy.com/9005-LED-Da...d_sku45_r4.htm
(there are A LOT of thread on these LEDs if you search)
Or you can use HIDs in them instead:
https://www.clublexus.com/forums/gs-...-hi-beams.html
I got my HID's installed today, (low beams, and fog) still trying to figure out the problem with the HID daytime running . . . when the tech put them in and set the switch to auto, they flickered like a strobe light so i'm still stuck with the ugly yellow looking color . . . 2006 GS 430 . . . any suggestions???? I went with the 8000k and they look GREAT!
Former Sponsor
Running HID's in the High Beam/DRL light will not work without any problems. Since the DRL mode is running at 6v and HID's require a solid 12v current, it'll flicker.
In theory, I guess you can use a capacitor and relay setup to draw a stable 12v current from the battery. Never tried it though, but it's food for thought.
Former Sponsor
Check out Osram Night Breaker Plus bulbs. These bulbs will give you a little more of a crisper, whiter color and will still be very functional when you go to use your high beams.
I want some Vossens for my 95;SC 400. You won thoses on your Lexus in your profile photo?
sleekbrian
06-22-10 01:31 PM
