Need help install OEM DRL to Philips D4S DRL
Hi Guys. Hope i can get some help here.
I had no problem installing new Philips CrystalVision Halogen Bulbs to my High Beam 9005 and Low Beam H11. However I am having issues install my DRL. It doesn't seem as easy as the other where you just plug and play. The power connector to my Stock DRL Bulb is completely different from the one I had purchased. Below is the new Philip D4S that I had purchased and did my research saying it works for my 2011 IS 250.
![](http://www.carhidkits.com/images/philipsd4S-hid-bulbs_2.jpg)
But the problem is the power connector is completely different from my stock DRL. The connector as you can see in the picture is a circle shaped where as compared to my stock DRL , it's just 2 straight line. Did I purchased the wrong one and do I need some special add-on? Sorry if I'm not as detailed as possible.
Please let me know if you have any questions that would help solve this issue. Thanks again!
PNice972
06-10-06 03:23 PM
