HID not lighting?
Guest
Posts: n/a
Ths weekend I met with a friend of mine to install some Phillips HID's. Got them in, turned the switch, and all that happened is the clicking of the relay for the ballasts. We tried them on his LEgend and they worked fine. What gives? I even turned the car on..no dice.
They are d2r/d2s Philips, 4100k bulbs.
If you havew any idea, please hit me on my two-way...I did a search but nothing about this.
For a member here, thanks.
Anyone?
As stated above, and this is for my SC400.
Plugged them in, the only signs of life were the relays clicking on to indicate they have power. Try the same setup on my friend's Acura Legend (both sides) and they shine very bright. Now my factory bulbs worked just fine afterwards in my SC. What gives? Does this mean I cannot use the Philips Kits and I have to use a retro kit or is it a relay that I need?
Any help is greatly appreciated.
I can also be reached on my two way at founders@legendarylegendz.com
are you using a relay?? if not i would try to make a relay. sometimes at the connector there is not enough power to actually spark the ballast to turn on the bulbs. so you use a relay which uses the power directly from the battery.
will do....I wish that there was some input from the other SC owners here. Does anyone else have any input? I guess I will play around with this while I am off for the next few weeks on vacation.
Are you sure the wiring is correct? You're not shorting that relay/ballast out somewhere? the relay should be wired directly to the battery...
Check out my install on my SC400...
https://www.clublexus.com/forums/sho...threadid=48111
Former Sponsor
This happened to me before. I bought a set of hids from a guy who had it installed on his bmw. When I put them on a GS300, they would not work. I am 99% certain you have to reverse the wires. Meaning the positive on the hid kit has to connect to the negative on your cars connector. And the negative has to connect to the positive.
Same thing happend to me last week with my Philips HID kit. What I needed to do was reverse the plug that triggers the relay from the car. The OEM plug that connects to your stock low beam bulbs plugs into one of the plugs on the ballast or relay ( depending on your kit ). If you do not get a response when the plugs are connected so they lock together reverse them, it will not damage the ballast's or bulbs. After doing this you should have light but you will need to reverse the plug on the hid kit reversing the wires or tape (cheap way) the plug in it's reverse order so it stays together. I thought this would not work because the oem plug wire and the HID kit wire that were being connected were red and I figured that was the positive, I was wrong. Most cars do not work this way, all you need to do is plug the harnesses together and it works. Lexus automobiles are different for some reason. I hope this does the trick. Also, the relay you are hearing now when you turn your lights on is the factory OEM relay. I heard the same thing and thought the kit was defective !!! Good Luck
I have also learned recently that the LENGTH of the wiring could effect the ballast's ability to spark up the lights...
From what I was told, a 13" length is "optimal"...so 13" worth of wire from the ballast to the battery...however, longer lengths can work fine (as my autolamps online kit is 18")
