Thought about 6000k hid kit I got.
Old 12-20-02, 03:07 AM
kapdori
kapdori's Avatar
Default Impression about 6000k hid kit I got.
Just wanted to share my impression on hella 6000k hid kit that I installed tonight. Overall, I am happy but its not fully what I have expected. It is definately much brighter and blue/whiter than my piaa extreme white bulb which I had before. I have same piaa bulb on my fogs and it looks yellowish now. Now here is my impression and question. After it warms up, the color is more white hue when looking directly at the light but the color is greenish on the road. I believe this might be due to greenish tint that 01 and on gs head light housing has. Most disappointment that I have is that the beam pattern. It seems to be not really focused sharply as I would like it to be. It is scattered out somewhat and maybe its because the bulb looks to be d2s bulb not d2r. I bought mine thru www.misterjung.com and I don't know if anyone bought from him or not. the kit is d2s bulb made into 9006 kit and quality is overall excellent but again I am not sure of beam pattern. Is there 6000k kit with d2r bulb?.
will d2r bulb be better than d2s bulb? thanks for all the help.
Old 12-20-02, 03:29 AM
rominl
exclusive matchup
rominl's Avatar
they always use d2s bulbs, no one use d2r bulbs. that's funny coz' i have the old 98 housing without the green tint and my light on the ground is absolutely white, so that's perfect. my headlight focus VERY well though, have you tried to adjust the height and see?
Old 12-20-02, 03:36 AM
INHOCJP
INHOCJP's Avatar
Default Re: Impression about 6000k hid kit I got.
I assume you're using the non-HID housing. Internally, the OEM HID housings are structurally different than the non-HID housings. This may be the cause of your problem. I was wondering, for those GS owners who have upgraded to HID's w/ aftermarket kits, have you had glare problems?
Old 12-20-02, 03:37 AM
rominl
exclusive matchup
rominl's Avatar
Default Re: Re: Impression about 6000k hid kit I got.
it is, but mine is just fine though. i agree it scatters a bit more than the hid housing but defintely it still focuses very well
Old 12-20-02, 03:40 AM
INHOCJP
INHOCJP's Avatar
Default Re: Re: Re: Impression about 6000k hid kit I got.
That's good. In any event, HID's look much better than stock halogens!
Old 12-20-02, 03:44 AM
rominl
exclusive matchup
rominl's Avatar
Default Re: Re: Re: Re: Impression about 6000k hid kit I got.
oh yeah, never ever any non-hid for me
Old 12-20-02, 04:05 AM
kapdori
kapdori's Avatar
I guess I will try to post some pictures tomorrow. The light IS very bright. I am happy with the kit, just wanted to see what might be the problem. Well, I will try to adjust the level too and see what happens. thanks
Old 12-20-02, 04:46 AM
indypwr
indypwr's Avatar
Post
kapdori:
how much did you pay for the 6000k kit?
most likely it is yr housing inside yr lights that causes that greenish output. i'm using 39 projectors with 4100k standard and it comes out really white. blue at first then turns white after warm up. h'ever, i'm planning to upgrade to 6000k but not sure what to get.
Old 12-20-02, 05:02 AM
rominl
exclusive matchup
rominl's Avatar
Originally posted by indypwr
kapdori:
the kit (philips bulbs and ballasts) i got was 460 shipped. steve has some 5300k kit for sale for around that price now too
for the 6000k bulbs (either d2s or d2r) i can get the philips ones for 250. synergy bought them from my contacts
Old 12-20-02, 04:08 PM
HarrierRX300
HarrierRX300's Avatar
Rominl,
I just bought some Hid's from misterjung for $380 with shipping included. Why did you pay $460 for them? I bought it from eBay too. I haven't had much problem with them.
But, man, those HID sure makes a difference.
Old 12-20-02, 05:34 PM
kapdori
kapdori's Avatar
Hey harrier,
I bought mine from mr jung also. How is your beam pattern?
Mine seems little scattered. Is yours also d2s bulb?
thanks
Old 12-20-02, 08:26 PM
rominl
exclusive matchup
rominl's Avatar
well i got it a while ago and that's the best price i could find on philips, so... philips are always the most expensive
Old 12-23-02, 04:17 PM
HarrierRX300
Kapkori,
How is the pattern? The displacement of the lights looks fine to me. Are you shining them against the wall and how far?
Old 12-26-02, 02:02 AM
tiguy99
tiguy99's Avatar
D2s is supposively for projector headlamps like first model ES300 or SC300/SC400/GS300.
D2R is for reflector lamps (i.e. LS400/LS430/GS430/GS300/GS400 ect)
D2R has the shield on the bulb that conforms to the reflective properties and shines the lights together with the HID reflectors properly. I don't know too much about using D2s on reflector other than several people flashing you because your lights are too bright. Next time, look at cars/ SUVs with HID of the relfective type. Notice how the light shines from the upper part of the lamp rather than the entire lamp. D2R is somewhat responsible for this.
My 0.02
Old 12-26-02, 02:17 AM
rominl
exclusive matchup
rominl's Avatar
My 0.02
yup you are right. for all cars with reflective type bulbs you always only see light on the upper part of the housing, that's exactly caused by the metal piece on the bulb. when you install the reflective bulb in the housing, the metal piece will appear at the top side. therefore no light will come out of that area, so no light will reflect off the top part of the reflector located in the middle of the housing (the one that stuck out from the back of the housing to the front). that's why no light goes to the bottom part of the reflective housing and so you don't see any
Quick Reply: Thought about 6000k hid kit I got.
