Sponsored by: CARiD
sc light question
Old 12-28-02 | 05:03 PM
ryanSC300lover's Avatar
ryanSC300lover
Default sc light question
i dont have money for HIDs
but want to get something brighter/nicer for my 92 sc300
any recommendations?
Old 12-28-02 | 09:47 PM
NAZTY97's Avatar
NAZTY97
I have a 97 SC400 and use PIAA super plasma's for the 9006's and H3 fog lights, and they are the same color as HID's,.. just not as intense, but brighter and clearer than stock.
Old 12-28-02 | 10:54 PM
ryanSC300lover
thanks man..where did u buy them and about how much should i pay?
Old 12-29-02 | 08:08 PM
DeadRinger's Avatar
DeadRinger
Quick facts...
All DOT approved 9006 bulbs are no brighter than about 1000lumens... HID's are about 3200 lumens or so... (this excludes the high wattage 9006 bulbs, which may be brighter, but you'll need to rewire to get enough current to them)
HID's are typically a temp of about 4100k... the closest you're gonna get with an incandescent bulb is a Sylvania Silverstar which is about 4000k... side by side (HID and SliverStar), they are pretty close to identcal in color.
So you can get the same color, but not the same brightness as HIDs.
To get additional brightness, I would recommend doing a 9005 swap which will get you closer to about 1700lumens. I've done such a swap and its a noticeable improvement in lightening - but doing a side-by-side with an HID set up, its still not as bright.
Here's how to do a 9006/9005 swap out:
http://www.bmwe34.net/E34main/Upgrade/More_light.htm
Good luck.
Old 12-30-02 | 04:24 AM
rominl's Avatar
rominl
exclusive matchup
CL Folding 10,000
or try the razo bulbs, they are pretty white
Old 12-31-02 | 08:27 PM
NAZTY97's Avatar
NAZTY97
look at the light on the ground in front of my car,... that's pretty damn white, and the footprint on the ground is awesome, blueish on the very outsides and white in the field of view,...
I pulled up next to an IS300 and out color was identical,... his was a little brighter.... ryan,.. just type in yahoo PIAA Super plasma and there should be this one site that has all aftermarket lights in a comparision cost table,.... I paid right at $90 for the 9006's and $75 for the fogs.
My thoughts are this,... I bought a whole sleu of other lights that were "higher" wattage and they kept either burning out prematurely in a matter of months or melting the harness and shortin' out.... no problems with the piaa's.
if i find the link...i'll post it later... i'm takin' a dj break right now and if i get a moment will find it for ya.
Old 12-31-02 | 10:47 PM
rominl's Avatar
rominl
exclusive matchup
CL Folding 10,000
piaa plasma white are good stuff
same with piaa extreme white
and from what i have heard/used/seen
razo and silverstars are pretty good too.
Old 12-31-02 | 10:49 PM
ryanSC300lover
thanks guys..is that 90 for one or a pair?
i work for acura..and wonder if the TL light bulbs would work ?
Old 12-31-02 | 10:51 PM
rominl's Avatar
rominl
exclusive matchup
CL Folding 10,000
yup, around 90 bucks a pair sounds right
i have the acura tl type s. which bulb you talking about? the headlight is hid (d2r) and it's just the same as the one used in most lexus with stock hid. the high beam on the tl is 9005, and the fogs on 02+ tl is 9006. but they are nothing spectecular (very yellow)
Old 12-31-02 | 10:53 PM
ryanSC300lover
if the TL has 9006 cant i use those for my lexus low beams??
Old 12-31-02 | 10:56 PM
rominl's Avatar
rominl
exclusive matchup
CL Folding 10,000
yes you can use the fog light bulbs from 02 or 03 tl, but then it's not really white, in fact very yellow compare to any stock hid (that's why i have change my fogs on the tl-s to 6000k hid too)
Old 12-31-02 | 10:58 PM
ryanSC300lover
i guess i am asking if there are any lights in teh acura lineup..that will bolt str8 into my sc300 headlights..cuz if it does..i can get them freee
will anything in the acura line up, after putting it in my car, make a difference over my stock lights?
and waht lights will fit where?
Old 12-31-02 | 11:05 PM
rominl's Avatar
rominl
exclusive matchup
CL Folding 10,000
umm..... i only know about the tl and cl. the tl fogs will fit. the others you can check would be the headlight of rsx and the fogs of the rl.
but none of those lights will be whiter/brighter than those from lexus though
and hey, do i get free bulbs too?
Old 12-31-02 | 11:07 PM
ryanSC300lover
hehe ya i can hook u up
hmm if they are not brigher...then its not worth it..
Old 12-31-02 | 11:21 PM
rominl's Avatar
rominl
exclusive matchup
CL Folding 10,000
nop, they are definitely not brighter. which part of CA you in?
