melted healight connector
I got a quick question...
My passenger side light went out yesterday and I went to pull the bulb out i noticed the whole headlight connector was like melted and corroded. Then I took a look at my driver side one and it is doing the same thing but that one is still functional. My question is, is the connector the same as any other toyota vehicle? Or do I have to go with a Lexus one? your help is greatly appreciated. BTW, its for a 95 GS300.
Thanks in advanced!!!!
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
yup, it will melt it down when you use wanna be "hid" bulbs..
i've also experienced that....
it melted by passnger side very bad and i had to soder both wires just to make it work.....but after a few weeks, i decided to do the "retrofit" like jmai22........
paid 700 bucks including labor and it wz worth it!!!
Yes...because if you read the box...it should say something like 55w->85w or something. It basically means that the "HID" bulb you're putting in is going to draw 85w of power whereas the factory connectors & wires were made to handle 55w or a little more. Most of the cheapy bulbs like Hiper and Eurolites or similar will most likely melt your harnesses. If you are intent on using the colored type of bulbs, PIAA and the Sylvania Silverstars are a good place to start. The PIAA's don't draw over factory current, and neither does the Silverstars. I believe the PIAA's are in the $70-$100 range, and the Silverstars are around $50. I learned the hard way. I heard the PIAA's also do not have a long life span. Shorter than most stock halogen bulbs anyways
. I also heard that Raybrig makes a bulb that doesn't draw over factory wattage, but don't quote me on that
If the harnesses are melted beyond repair, the only option is to buy new harnesses from the dealer...which means $$. You can also PM Steve from Carson Toyota as he seems to be the man around ClubLexus for OEM & Aftermarket parts. His username is SUPRATRD.
Originally posted by gatewaycraig
umm...yes im guilty....i thought of that after i posted...is that the reason this happened?
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
don't go to the dealer. all you have to do is cut your factory wires and buy new 9006 connectors. i can get them for 10 bucks a piece. thats the price i can get them for. and i'll hook you up. you can't find them anywhere unless you go to a junkyard and snip them.
Originally posted by Rico's Revenge
Actually, I hve found the 9006 coneectors at Autozone for $1.99 each. I always carry a couple in the glove box after the same thing happened to me.
Master Thread Closer!!
Good point..... but is it really drawing 85w of power? The bulb itself is labeled 55w. Which is it?
PHML
