OEM HID Help
OEM HID Help
Ok so I have a 98 GS400 with halogens. i bought 2 OEM denso ballasts with 2 "power connectors" and 2 6000k bulbs... i was wondering if anyone can tell me what else i will need to install the ballasts. i read somewhere that i would need to splice a female 9006 connector. I dont want to retrofit projectors if i dont have to. Any help would be great.
link for ballast and connector. wont let me save the picture from their site.
http://www.distantxtremes.com/oem-hid.html
Well my main reason was the Denso ballast is way, way more reliable than any aftermarket ballast. Second reason being so i could have a clean install in the OEM spot on the headlight housing. But i got them installed. Had to get a d2s to amp conversion harness and they work like a charm no flickering, nice color, and quick warmup time.
I disagree about the longevity of a Denso ballast vs a high quality ballast. To each their own i suppose. But consider that you my have to get a whole different housing to accommodate the D2R bulbs and ballasts. The aftermarket kit is a simple plug and play. And if you want to get fancy with it so no one can see, just tuck the kit nicely.
