help on fogs
Old 01-21-03, 11:23 PM
HeKtic IS
HeKtic IS's Avatar
Default help on fogs
can you guys give me information about the hole fog light. how does the yellow come out? how do i get that pure white, xenon or ? is der a way for me to take the yellow out? or do i have to replace the whole fog light? thnx
Old 01-21-03, 11:36 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
the bulb inside is clear, but htere is a yellow lens in front of the bulb that makes the output yellow. you can break the lens but it's very hard (very thick glass) and also it might not produce as clear a light output
Old 01-22-03, 02:21 PM
baadhabit
baadhabit's Avatar
like rominl said the bulb is clear but theres a yellow lense that gives the color. you can break the lense piece but you'd have to take the light apart to get to the lense. lots of work plus may not be worth it because once youre done it doesnt look as clean because the bulb is more noticable.
you can do all that or you can find someone who can import the clear ones from japan. sometimes they sell them on ebay.
Old 01-23-03, 12:42 AM
GS3Tek
Forum Moderator
GS3Tek's Avatar
Default Yellow fog lights
Do you want to sell your yellow fog lights? I need the passenger (R) side. You can buy the xenon replacements to make them brighter and whiter.
Old 01-23-03, 12:46 AM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
Default Re: Yellow fog lights
who you asking?! the guy has is300
Old 01-25-03, 06:34 PM
Blanco
Blanco's Avatar
Question Crystal Ion
I'm curious about something. We all know about the yellow lens with the white bulb in the fogs. My question is, has anyone tried or seen anyone with the PIAA "Ion" bulbs swapped for stock??? I'm wondering how much "yellower" it would look. I like the look of the stock yellow fogs on my GS4, i'm just wondering how they'd look if they were even more yellow, and just as bright.
Old 01-27-03, 02:48 AM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
Default Re: Crystal Ion
i have never tried it but my guess is it won't be any yellower. i put in super white (which is higher wattage) in my yellow fogs and the output is brighter, but still just the same yellow. basically the yellow lens will filter out everything except the yellow, so putting the ion probably won't make any difference
Old 01-27-03, 11:02 AM
Blanco
Blanco's Avatar
Question
BTW, what is the bulb type that goes in the fog light housing?? I've seen several different references, and want to get the right one.
Old 01-27-03, 05:09 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
what car? if it's gs, the fogs are 9006, or hb4
Old 01-27-03, 11:48 PM
Blanco
Blanco's Avatar
Question
9006 or hb4?? Why two?? I've got a 98 GS4 w/HID. Will both work, or only one?? Know any good websites to order the crystal ion bulbs from??
thanks,
Blanco
Old 01-28-03, 12:01 AM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
thanks,
Blanco
yup, they are both the same type, in japan i think they are referred as hb4 often.
tried optauto.com?
Old 01-28-03, 10:26 PM
Blanco
Blanco's Avatar
Question
optauto.com didn't have the crystal ion bulbs listed. Can you think of any other websites???
Old 01-29-03, 03:39 AM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
umm...... i can try, i will see if i can find something tonight
Old 02-02-03, 05:10 AM
Hameed
EV ftw!!!
Hameed's Avatar
FYI, I broke the yellow glass in my fogs and the lights look really sharp. I put in extreme-white PIAA lights in mine and they look just fine. I will post some pics later this week to show you all....
Old 02-02-03, 10:07 AM
Blanco
Blanco's Avatar
Question ??
Any luck?? I haven't been able to find any.
Quick Reply: help on fogs
