curious bout my yellow fogs
If i put a different bulb in my yellow fog light housing is there any way i could change the color or hue or brightness of it. any different bulbs i could use. thanks
well it's going to be yellow for sure, but yes it can be brighter. i have yellow fogs and i put in a super white bulb. i don't care about the white, i care about the wattage, which is higher than the stock 51w. so my fogs are brighter than the stock ones, but still as yellow
The stock bulb Lexus gives you is 51w just for longevity purposes. The 9006 standard is actually 55w. If you want to hack a 9005 bulb, it is 65w and does not have a capped tip. It is safe to run a 9005 in a 9006 socket plug and play and the brightness gain will be noticeable. They usually cost the same price too. Try Sylvania Silverstar 9005 or Philips VisionPlus 9005. I'm not familiar with the GS fog assembly so I don't know if it'd support an 85w bulb. That's a risk you're going to have to take
If you want a different hue, you could try playing with the ion bulbs out there. they use a thin coat of ion film that creates a dynamic color hue with minimal brightness loss. I don't know how the yellow glass tube in teh foglights effects the ion bulbs though.
If you want to change the color, you're going to have to remove the yellow glass tube in your foglight assembly.
ToyotaLexus
09-30-01 06:14 AM
