Do H3C H.I.D. exist?
Hey gang~~I got an 93 LS400 with H4 headlight and H3C foglights. First, I want to put H.I.D. for the fog light(I already had the headlight converted to H.I.D.) Do they even make H3C H.I.D. bulbs? And second.....I lose my foglight due to the H.I.D. conversion. Does anyone know how to re-wire the foglight to somewhere else so I can still use them.....Thanks so much for the help.
Originally posted by retrodrive
This is my next weeks project. Should br easy to do with voltmeter and a solder iron. I'll post the results.
are H3c same as H3. if they are it would be pointless to put HID in a H3 housing. 1 reason. the Filament in a H3 bulb is perpedicular to the bulb which allows the light to be shot straight out. which means the housing was designed to just keep the light straight. now if you put in a HID bulb the capsule is at the center and the majority of the light comes out the side of the bulb. the H3 housing wasn't designed to have all this light shot to the side like that. H3 is the only bulb with its filament perpedicular to the actualy bulb. i have already tried to put HID in a h3 housing. it was BAD.
Oh why~Oh why~~~~
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Search Function Inc.
Yeah, I should talk to BHC, so far I have followed ate things that he has done and it was just as he described it. I really have a lot of props for that guy ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
I am pretty sure that the fogs wiring is so simple I won't need help though. Wanna try and mess with my flashlights too.
I did that mod on my '90 LS, and I just added some cut aluminum to help shield certain parts of the casing. That blocked off areas that would allow excessive glare. It still does have more glare because the reflector obviously wasn't made for HID, but I have Ultinons (dimmer), and everyone in Seattle is used to HID's.
Rewiring your foglights to your parking lights should solve the problem with losing your fogs with a HID kit.
Originally posted by CelsiorUCF10/11
no they are not the same bulbs Jmai, The H3c is a plug in and the H3 requires a wire attachment of some sorts.
So E.........Do u know how to do it?
Try Kempo in San Gabriel, they should know because they rewired my signal lights to my headlights. Im pretty sure they can do it.
