Wedge bulb replacement on GS
I seem to remember someone posting a DIY on how to replace the wedge bulbs on the GS, but could not find it. Anyone have any info they can give me? One of them went out.
I am pretty sure I'm going to get the Polarg M4 as a replacement, as it seems to be the best for use with HID.
You're asking about the wedge bulbs for the daytime running lights right? You might wanna try a Polarg M6 bulb instead of the M4 (M4 is a little too dim for most people). Here's a couple links that might help:
https://www.clublexus.com/Informatio...rg/polarg.html
https://www.clublexus.com/Informatio...s/m6bulbs.html
have you considered using LEDs for the wedge bulbs?? That's what I did, and I love it. I got the dual white/white LEDs from PIAA and they are nice and bright with a purplish color. Got them at autodynamic.com
Plus if you use LEDs you will most likely NEVER have to replace them, since they don't burn out like conventional bulbs.
Master Thread Closer!!
ebruceii:
How much did a pair of those LEDs cost you? Got any night pics of them ON? Do you have HIDs? How do they match with your HIDs?
Correct me if Im wrong, but dont they sell them in other colors too?
Thanks!
Thanks!
Re: Wedge bulb replacement on GS
http://www.digitalsimple.com/M6%20Page.htm
Originally posted by BR1AN
You're asking about the wedge bulbs for the daytime running lights right? You might wanna try a Polarg M6 bulb instead of the M4 (M4 is a little too dim for most people). Here's a couple links that might help: ...[/URL]
Originally posted by PHML
ebruceii:
Thanks!
ebruceii:
Thanks!
Thanks for the reply.....a few more questions.
Do you have the single LED wedge bulb or the 4 LED wedge bulb?
Was it difficult (like M6) to install? Did you have to cut the wedge opening to get it in?
Oh, and the site I got them from was xtremewhite.com
ebruceii:
Thanks again for the info.
Any idea what kind of lumens these LEDs are pushing out? Will the 4 LED bulb be too bright?
Btw... is the white really "white"? Any hint of blue at all? The blue LEDs are really blue.
PHML
PHML
ebruceii:
PHML
ebruceii:
PHML
Originally posted by ebruceii
No problem. Actually I had the single-LED "bulbs" in my wedges before. They worked fine, but weren't bright enough for me. The PIAA bulbs that I put in are dual-bulb setup, meaning two LEDs per bulb. Much better light output, obviously. The PIAAs were a little harder to get in due to their overall length. No cutting was involved, just alittle extra care and patience. The driver's side is a tighter squeeze to get in, but after about 5 or 6 tries it worked. Just take your time and it's no sweat.
Min order is 10 items!!! But figure the GS uses 12 of 'em on the car.
