Help! something wrong with my headlights
I would like to know if anyone else has experienced this problem....for the past couple of weeks my headlights have been radomly coming on an off when im driving at night, checked the bulbs that i have and they seem fine, sometimes if i shake the wiring that is connected to the bulb it self it will come on but most of the time im driving around with only one headlight....and a couple of times they have both gone out at the same time.......does anyone know what the problem is????
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
i have the same problem my right headlight is always turning off i had to nudge the terminal a bit, what i suggest nudge the terminal untill the light goes on and then do something to keep it that way hence, i put a plastic ring around the terminal no problems so far. Which headlight is yours having a problem with ?
