Factory HIDs - Replacement / Upgraded D2R Bulbs
Old 08-28-14, 10:27 AM
PeteGS300
PeteGS300's Avatar
Default Factory HIDs - Replacement / Upgraded D2R Bulbs
Hi,
Well as its coming up to winter soon and i'll be doing more low light & night time driving.I'm thinking about buying some replacement / upgraded D2R bulbs.
I've used a headlight restore kit to polish the headlight lenses back to clear again but i'm finding to light out put of my factory hids to still be poor.
So i thinking new bulbs should make a improvement.I was wondering what bulb manufacturers i should look at.
Philips - Osram - Other
Can advice would be much appreciated
Thanks
Pete
Old 08-28-14, 11:05 AM
Ava92
Ava92's Avatar
I was in this situation and this is what I have gathered:
Best light output available right now: Osram Xenarc CBI
If you're looking for a bit cheaper option: Morimoto XB35
In the end I don't think you can go wrong with a nice Philips either though, they are OEM on tons of cars after all
Old 08-28-14, 04:17 PM
raytseng
raytseng's Avatar
Originally Posted by PeteGS300
Hi,
Thanks
Pete
Regarding the headlight restore kit. Be sure your kit includes sealant to provide UV protection to the plastic otherwise they will go cloudy again within 1 summer.
I suggest if you want it more permanent to get PPF on top of whatever sealant you have.
New bulbs will be brighter. I've only used Philips (same as OEM) to replace rather then upgrade; but those did increase brightness over my 12year old bulbs.
I bought on ebay to save some money, but at least from a high-rated seller that had in his description all the info to convince you he was selling genuine philips parts and not counterfeit ones. His price was also not insanely cheap price, but still some savings.
There is a link in the DIY in that explains exactly how to replace the bulbs, read specifically for the tips on how to detach and reattach the metal cap; that's the trickiest bit
Old 08-28-14, 11:17 PM
istundra
istundra's Avatar
be careful of counterfeit philips bulbs.
i would stick to Osram to be safe!
Old 08-29-14, 01:58 AM
angus
angus's Avatar
I may try to use 55w ballasts with the OEM bulbs and see if it's brighter.
Old 08-29-14, 03:35 AM
Lutkis
Lutkis's Avatar
They won't last long and you might burn your bezels if they overheat.
Atleast I'd think so..
Old 08-29-14, 10:03 AM
PeteGS300
PeteGS300's Avatar
Just placed an order on Amazon for a pair of Osram Xenarc 66250CBI D2R.
Anyone using these bulbs in their factory HIDs?
Old 08-29-14, 11:22 AM
istundra
istundra's Avatar
how much and which reseller?
i'm currently running 2nd set of HID Extra D2C i paid for $40 a pair. they last me about 2 yrs on last set. once one of them on this 2nd set burn-out, i will swap in the spare from my 1st set to buy some time. when that happens, i plan to buy my back-up to be Xenarc CBI 5000K D2R.
How much did you pay on Amazon?
I've used about 3 sets of aftermarket D2C bulbs in my car already and work fine.
just be careful not to push too hard when replacing it. cuz you do not want to mess up the auto-leveling.
Thanks
Old 08-30-14, 12:19 AM
PeteGS300
PeteGS300's Avatar
I paid £93.58 shipped which works out at $155.36.
Seller was called Upgrade Bulbs or something similar to that.
Thanks for the advice about the auto leveling will keep that in mind when fitting the new bulbs.
Why do the buy D2C bulbs when a 2gs is D2R?
Old 08-31-14, 02:09 AM
Fury82
Fury82's Avatar
I prefer Phillips
Old 08-31-14, 11:18 AM
istundra
istundra's Avatar
D2C is aftermarket fitment that can be used for D2R or D2S that is made by China and Korea HID Kit bulb makers.
You're correct, our car is D2R.
OEM bulb makers do not make D2C. They only make D2R and D2S.
Old 09-12-14, 05:32 PM
9aristo
9aristo's Avatar
if you're inclined, a projector retrofit.
alohatorn
12-26-14 06:09 PM
samasaurus
RX - 1st Gen (1999-2003)
01-29-12 06:21 PM
dtLS400
10-02-11 08:46 AM
SilverSprt
06-18-11 12:16 PM
Panerai127
01-31-07 10:27 PM
Quick Reply: Factory HIDs - Replacement / Upgraded D2R Bulbs
