base of the D2S bulb will it fit a GS3 01' ?
Old 03-11-03, 09:03 PM
rominl
exclusive matchup
rominl's Avatar
Originally posted by PHML
99SHIude:
Thanks for the tip....I was looking at it last night and it made sense to swap the bulbs out first to see how much slack I had to mount the ballast. Where did you run the wire to the driver side ballast? Above radiator fan? In front of radiator?
Yah....if you look at the short notch on the 9006 base....its directly across from the return wire.....thus, when short notch is facing up, the return wire is facing down.
Pete
hey pete, something doesn't sound right. shoudln't you be using the stock power connector, that's already one on the left and one on the right?? that's the case for me. so i don't have to run any wires from the battery, or from left to right, etc...?
Old 03-11-03, 09:04 PM
rominl
exclusive matchup
rominl's Avatar
for those who are confused about the bulb type, etc... go read the other thread i posted in this forum
Old 03-11-03, 09:17 PM
99SHlude
99SHlude's Avatar
The kit I got uses a seperate wire harness. I'm not sure if you have the same kit or not but I have to hook up a seperate harness for my HIDs.
Old 03-12-03, 01:38 AM
PHML
Master Thread Closer!!
PHML's Avatar
Hey guys.....according to the manual and the wires I got.....looks like I gotta tap into the battery (+red).....which then connects to the 20 amp fuse, and then to a ground (- negative).
Here's a pic of my wires.
Attached Thumbnails base of the D2S bulb will it fit a GS3 01' ?-picture-185.jpg
Old 03-12-03, 01:44 AM
PHML
PHML's Avatar
Just the wires..... notice the red wire (to battery) / black wire (ground).....the rest of the wires requires me to run it from passenger side housing - in front of the car near the radiator - to driver side housing.....Don't think its long enough to run along back side of engine area then down driver side.
Attached Thumbnails base of the D2S bulb will it fit a GS3 01' ?-picture-189.jpg
Old 03-12-03, 08:35 AM
rominl
exclusive matchup
rominl's Avatar
oh, this is a different kit than the one i had. the one i had, the wiring is two separate set, one for left and one for right, so there are also two relays as well. but yeah, with yours, you need to run the wire from left to right along the radiator area. and you will need to run the two wires to battery and gnd too. interesting setup
Old 03-12-03, 09:50 AM
PHML
PHML's Avatar
Hey guys....thanks for picking up on the wiring details. Yah....I guess my description didnt really make sense at all to you. A bit different from your setup.
Btw, is it ok to use only one relay for both ballasts? Logically, its probably more stress on the relay. I'm not a electrical guru, but I figure whomever built this wiring set deemed it reliable enough to offer a warranty.
Old 03-12-03, 12:19 PM
rominl
exclusive matchup
rominl's Avatar
i guess that's why there is a direct line from the relay to the battery for power. in my setup that line is missing, so it means it draws everything from the stock wires
Old 03-12-03, 12:23 PM
PHML
PHML's Avatar
Rominl:
Maybe that warrants you updating you DIY for HID conversion kit to show both wiring setups.
Pete
Old 03-12-03, 10:52 PM
rominl
exclusive matchup
rominl's Avatar
Rominl:
Pete
well you have the kit, maybe you can take some pics and we will go from there
Old 03-13-03, 10:50 AM
PHML
PHML's Avatar
I got same problems like GS300Rich. Popped both 15 amp fuses.
https://www.clublexus.com/forums/sho...threadid=77130
wing0
RX - 1st Gen (1999-2003)
31
09-11-12 01:37 PM
skaiyun
Lighting
02-26-08 08:59 PM
np20412
Lighting
07-27-06 06:25 PM
LEXISM
Lighting
15
05-24-05 03:52 AM
jersey1
Lighting
09-08-03 09:02 AM
Quick Reply: base of the D2S bulb will it fit a GS3 01' ?
