Removing dome light bulbs
Are you talking about the 192/168 bulbs in the map lights, or the long festoon bulbs?
Festoon bulbs should pop right out if you press the one tab.
For the peanut bulbs, I found that taking a thicker rubber band and wrapping it around the bulb helps to give it just enough grip to pull it out. That's what I had to do in my CT.
![](https://cimg9.ibsrv.net/gimg/www.clublexus.com-vbulletin/640x480/79441f41_f205_4980_a975_a3319117418c_0ec0447712fea56ca78d0e993f8f724d658d100b.jpeg)
