Fixed PRND2L lights
Fixed PRND2L lights
Just fixed the PRD2L light today because I was an idiot and messed them up. From the time I found out I received the bulbs to the time I was back in my room was 8 minutes - tops. When I first received the package I thought that somebeody sent the wrong product because it didn't come with the mounting base, but then I realized I had to reconnect it. It was cake. Highly recommend fixing it. Thanks Brian for the bulbs!
BTW, if I remove the blue covering, will it be any brighter? The climate control lighting makes it look weak.
Keeper of the light
2. Yes.
3. also, you can route switched 12v to the bulb and brighten it up a bit, it's only running off 6 right now. the cig plug would be a good place to grab the wires.
