Any Idea How to Wire These Fog Lights???
![](https://cimg8.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/image_68b685e509379df3a276c7c5393ba11b4fb79bf2.jpeg)
This 3IS conversion bumper for the 2IS I recently bought used comes with some fog lights installed. Only problem is that it looks like the previous owner sliced off the wiring and was vague about how to wire them to connect to the oem on my 2IS. Will update with photos later today. I was wondering how I would be able to connect the wiring, would I have to cut my oem off and rewire or was there another way I could keep the oem untouched but buy a connector/adapter for the custom fog lights that were sliced?
Yes. you can do that but you would need connectors that are compatible with the OEM fog light connectors. And if you do decide to use the splicers it would make it a bit more difficult to disconnect in case of an issue. If you cant manage to source OEM connectors you can get yourself a small wiring kit and solder connectors in a bit down stream from the wire terminals. That is, if you're handy with a soldering iron.
n/aisweak
Performance & Maintenance
04-20-17 10:06 AM
