Upgrade from 9004 to H4
Old 05-22-03 | 08:50 AM
Lvangundy
Guest
Posts: n/a
Default Upgrade from 9004 to H4
The 1990 LS's have 9004 type bulbs correct?
The 1993's have H4?
Can I upgrade to an H4 bulb? Or should I swap out the whole headlight unit?
Old 05-27-03 | 07:34 AM
Lvangundy
Guest
Posts: n/a
bump/
Just wondering if anyone has done this or tried it - I'm waiting on a HID kit.
Old 03-01-04 | 06:01 PM
dj.ctwatt's Avatar
dj.ctwatt
I've been very interested in doing this too. I have a feeling that 9007's might fit, but I havn't tried. It's only a 10 watt gain. They sell H4 retrofit kits at kragen now that are supposed to work on ANY car. . . have you had any luck with a conversion or fitting newer LS headlights?
Old 03-01-04 | 08:46 PM
EXE.UCF10's Avatar
EXE.UCF10
VIP|EXEstyle セルシオ
It wouldn't work very well unless you changed the headlight assembly to the later '93-'94 models. If you try using a H4 bulb in a 9004 assembly, you get a completely different, unfocused/scattered beam pattern that just emits a lot of glare.
BTW dj.ctwatt, this is a pretty old post.
qz0kck
ES - 5th Gen (2007-2012)
09-17-18 11:30 AM
gxman1
GX - 1st Gen (2003-2009)
02-09-14 12:09 PM
Jaybeck860
IS - 1st Gen (2001-2005)
01-27-14 11:08 PM
newgsman
02-20-09 09:47 AM
ewitherspo
02-11-09 11:18 AM
Quick Reply: Upgrade from 9004 to H4
