Underpowered 6000k's? Yellowing on bottom? (Pics)
Master Thread Closer!!
Originally posted by brendanlim
I think so too ... I'm not sure ... I definately hope so. He mentioned that he had the 1 year warranty on the "whole kit".
Ugh.. this is making me have a horrible start to my day
Jason has to decide whether or NOT its a manufacturers defect, or if its a result of you swapping the wire to the battery.
Good luck. Let me know what happens.
Pete
Originally posted by PHML
That'll be cool if Jason did.
Pete
Pete
I'll let you guys know what happens
Confirmed. It's not the bulbs. One of my friend's whom I refered to Jason for his 6000k kit came over and we tried swapping bulbs and for me the situation was the same and my bulbs worked properly in his car. Jason and I think that it may be the ballasts.
By the fact that you took the fuse out and it still worked means that there is a wiring problem that may be the cause. For example, there may be too much grounding (bad wiring at the relay) and not enough current (high gauge wire) and that may affect the incoming power.
My friend and I swapped bulbs in the daytime and tested them outside and it looked fine. We haven't tried it at night though (when the problem is indeed evident) -- We will try tonight and see.
Originally posted by rominl
damn, this is so weird man... it's easy to check the voltage on the battery right?
I'll be checking today at AutoZone.
After all of this trouble I'm thinking it may be the battery .. if so then I'd feel so stupid.
In either case.....you scored some free stuff (ballasts and wiring) from Jason.
Pete
