2000 GS300 --> lighting
2000 GS300
Help please...3 questions
1. How do I install the front clear side marker?
2. My fog lights are yellow, I tried to change the bulb to clear, but they are still yellow, what should I do?
3. My front turn signals are yellow, how do I change them to clear? Is it the lense or just a bulb?
1. Install clear corners
https://www.clublexus.com/forums/sho...+clear+corners
2. The yellow is coming from the the lens in the fog light. You can advertise in Classified section, I'm sure someone with clear fogs would want to swap w/ your yellows, since the yellows only came with HID lights.
3. Clear turn signal:
https://www.clublexus.com/forums/sho...n+signal+clear
I just found some links by searching. I'm sure you can find more using the search. Good luck and Welcome!
Chumacher
06-12-08 10:55 AM
