is this true about hid?
that you need a stronger alternator to run hids without your car dying on you after like a month? Also anyone know any good cheap places to get hids... I want pure white light.. 4300k i believe it is..
Re: is this true about hid?
However, you do need a battery relay to reduce the draw from the alternator when the ignitors fire up.
i can get hids for 375.. i doubt they are hella ballast though. They are 8000k..
The color output of 8000k's are also really really blue. Skyish blue. Ricey looking in my opinion -- not the kind of reaction you'd want after shelling out that kind of money for HID's.
Also, the only real bulbs (no coating) that can achieve a higher color temperature than 4100k/4300k's are Philips Ultinon 6000k's. Most of the 8000k or higher color temp. bulbs are cheap Korean bulbs that end up blowing after a short period of time. The Philip's bulbs should outlast the life of your car with normal use.
PHML, rominl, SouthernSunGS, and I (there are others too) bought out Philips 6000k kit from a vendor that sells the kits at a great price with 100% quality parts. His name is Jason and he can be reached at: discountcycle@ureach.com -- His kits go for around $455 shipped. If you go to groupbuycenter.com and search for 6000k then you can find a group buy led by him (most of the time when he has them in stock). Do a search on 6000k and you can see the color temp they put out. It makes stock HID look yellow
O.C. Lucky Strike Fanatic
BRYAN!!
EV ftw!!!
I got my 6000K Philips Ultinon HID kit for the 9006 housing (fogs on a 2nd gen GS) for $420.00 shipped to Canada from Jason!
Awesome lighting now. Now I have to upgrade the stock OEM HID low beams from 4100K to 6000K because they don't look so white now with the fogs on..............
EV ftw!!!
This is a good pic of my HID's in the fogs and ofcourse the OEM HID's in the low beams
