99 LS400 right front turn signal
Hello,
I recently purchased a 99 LS 400, and noticed the right front turn signal assembly is loose. I removed the top screw and pulled the entire lens assembly out, and noticed the plastic grommet in the fender was broken, so I installed a new one. This didn't hold the assembly tightly in the fender, so I was wondering:
Can someone explain how this fixture is held in the fender and also to the headlight next to it?
(I noticed there is also a tab on the inside of the turn signal assembly that appears to "lock" into a rectangular hole mounted on the headlight next to it, if this helps). Any help would be greatly appreciated as I really don't want to pull the other side off if I don't have to.
Mark
Mark
dantampa
10-16-09 01:48 PM
