I recently went through and did a power steering system overhaul on the Lexus. Afterwards I cleaned the engine bay so I could watch for any new leaks. I noticed a small leak up front on the passenger side. I went through and snuggled up some of the valve cover bolts I could reach but not sure that’s the issue. Does anyone have any idea where I should start looking and researching to tackle this last leak?
since you touched the power steering system, it's likely related to the PS. did you replace the o-ring at the bottom of the PS reservoir as it enters the pump?
