98 LS400 Power Steering Tight
98 LS400 Power Steering leaking
Today when I was turning my steering to either direction in extreme, there was a loud screeching noise on either side. I continued to drive with it and pulled on to a parking lot and checked fluid, it was on low end but I made it home with that. It was just extremely tight to turn the steering even to the slightest.
I replaced my PS pump with AC Delco Reman in 03/19,
https://www.clublexus.com/forums/ls-...endations.html
And I did replace the acv valve too. So anybody have suggestions on where to start from? Is this ps pump itself or something else would be a culprit (?)
EDIT leak was from stress fracture on the high pressure line. the pump still works good.
Exactly right. leak is happening somewhere,
https://streamable.com/9n39dj
https://streamable.com/f8fkpa
https://streamable.com/7ivggl. - best shot I could get!
Please let me know your thoughts
I would also check out the alternator in case it is soaked now...
My guess too high pressure line. Haven't checked alternator yet but it's pissing on the side. Can someone tell me the pn for the washer.
Here are the videos, I used the boroscope camera so please barr the resolution
https://streamable.com/10rfd3 front view
https://streamable.com/shiqf1 top side view
https://streamable.com/uj4toq top view
https://streamable.com/sa1zru aftermath
Looks I replaced the O rings but not the high pressure washer,
https://www.clublexus.com/forums/ls-...l#post10415381
Looks I want this part, right?
https://parts.rallyelexus.com/p/Lexu...432730030.html
https://parts.rallyelexus.com/a/Lexu...1420-4503.html
My guess too high pressure line. Haven't checked alternator yet but it's pissing on the side. Can someone tell me the pn for the washer. Here are the videos, I used the boroscope camera so please barr the resolution https://streamable.com/10rfd3 front viewhttps://streamable.com/shiqf1 top side view https://streamable.com/uj4toq top view https://streamable.com/sa1zru aftermath
Looks I replaced the O rings but not the high pressure washer,https://www.clublexus.com/forums/ls-...l#post10415381 Looks I want this part, right? https://parts.rallyelexus.com/p/Lexu...432730030.html https://parts.rallyelexus.com/a/Lexu...1420-4503.html
Thanks. Looks like I have the washer. But can it still leak?
I'm just going to drain the reservoir and unbolt the high pressure line with pump in place. Any precautions to take place? Would replace the washer and see if it works. My fear is I don't want the pump to be leaking from somewhere near that union.
https://streamable.com/gu8ao0
fondu (03-23-23)
I just replaced the crush washer and found it's still leaking. I was able to get another video (last 15 secs in both). Anybody think my union itself leaking at the joint? If so, I'm considering to get some sealant that can withstand such a pressure to test to. Any recommendations?
https://streamable.com/k1wkkj
https://streamable.com/3s3yyd
The 400 PS system is far from perfect. We all know this, but the banjo bolt and crush washer is a very reliable design. I'm wondering if it's not something on the pump itself leaking within close proximity to the banjo bolt.
44338A (O ring) possibly..?
