Ls 400 won't run
4th Gear
95 Ls 400 , driving one day and it just died and I smelled electrical burn , pulled ecu and sure enough capacitor leaked and burnt the board , I had another on hand and put it in , now when I hook obd reader it says no link , I have checked fuses and all good , still won't start , no power to fuel pump , any help would be appreciated , I tried to bypass by jumping b+ to fp with no luck then checked voltage from b+ and ground and got.38 with key on ? Where am I losing voltage? Before I lose my mind
as99east (04-19-23)
4th Gear
The ecu was original one that came with car, I had put the one that burned out in car about 8 months prior , I'm aware of serial nos matching , have new battery but no power to pump
4th Gear
I also have no power to fuel pump relay at fuse block with key on , I have refurbished ecu (lifetime warranty) still "no link"
I have no spark also , is there a security cut-off switch or something , I've checked the fuses under hood and under dash drivers side , help please
4th Gear
Regarding no communication with the ECU - What code reader are you using (brand and model no.)? Confirm that your code reader is SAE J1978 compliant.
A wiring diagram (Engine Control) for a 1995 model year might be helpful.
I would think that the '95 and '98 are wired similarly.
![](https://cimg3.ibsrv.net/gimg/www.clublexus.com-vbulletin/1228x950/untitled_56_1fc8e61be21ad54db3ff27df6fbcf344531c9ea2.jpg)
'98 Electrical Service Manual
