LS400 1999 Brake light bulbs not fitting! help!
9th Gear
Hey there, I recently changed out my LS OEM taillights for a pair of clear tails I made! I ordered a couple of red LED bulbs because the stock bulbs are of course, not red. I go through 3+ different brand of red LED bulbs trying to find a pair that fit. ALL of them will not fit into the bulb housing. The LED bulbs seem to have a tab that the bulb housing is not liking, hence it not fitting. I finally found a pair that fit and of course then they were to long, touching the inside of the clear tails, those didn't work. THEN I found bulbs that finally fit and worked great. Then they all burnt out in under a year. Someone with any good red bulbs, LED or not, please chime in. THANKS! <3
Can you post the bulb numbers/brands/types you've already tried?
9th Gear
I don't exactly remember all the brands I've tried because I have had them all returned. They all stated that they were 7443, I believe that is the correct size, right?
The only ones that have fit so far are these amazon brand Brightstar 7443 7440 T20 LED bulbs.
According to this they should be 7443.
https://www.sylvania-automotive.com/bulb-finder.html
Sylvania states their red LED's should be used behind a RED LENS. Phillips red LED's have no such direction.
sarah
RX - 1st Gen (1999-2003)
07-28-09 11:28 PM
