98 transmission pan drop
The lata owner did replacement filter at 182 and now I'm trying to drop the pan but seems they used a black rtv stuff and I don't know what it is. Anybody have tips and how to remove them?
Back story, when I did 8qt drain and refill through return line my transmission worked great for three or so days but now it back to where it was (I need to rev past 3k RPM for my gear to shift from N to D, rest all gears smoothly once it's in motion which indicates a clogged transmission filter I guess).
Here is the pic of black rtv excess that's visible.
https://imgur.com/a/GwehbGx
I'm thinking should I just do a return line drain and refill again and install transmission inline filter to catch the small particles instead of dropping the pan. Thoughts? My understanding is the fluid gets filtered before it returns back to transmission with this method so I could save myself the hassle of damaging the pan
Pan removal is pretty easy IF you have the correct tool. Once the pan starts to give way, it should come off the rest of the way with a tug. Use caution that the mating surface on the transmission case isn't gouged.
Most replacement filter kits come with a gasket if you don't want to deal with FIPG.
The following 2 users liked this post by paulo57509:
BNastee (05-08-23),
Stroock639 (05-07-23)
https://www.amazon.com/s?k=gasket+se...f=nb_sb_noss_2
Here is my pan removal tool which I inherited from my grandfather:
I've used this several times without any pan damage. You might be able to make / rig something like this with a hack saw blade
GHBabie
RX - 1st Gen (1999-2003)
58
09-03-22 08:31 PM
