96 ls400 p1305
5th Gear
I've been combing through the forums and can't solve this issue. P1305 fault. Both coil packs are good. Both igniter are good. Both ignition rotors and distributor caps just replaced. Still no spark from half the cylinders. Low voltage reading going into that coil pack. Any info or suggestions would be greatly appreciated.
5th Gear
Looks like I'm going to keep chasing wires. Found wiring schematics at 1996 ls400 system wiring diagrams
5th Gear
So all the wiring is checking good. Had the ecu pulled and taken to an electronics diagnosis center. They took it apart and said "it looked ok". Im suspecting this is the ecu capacitor problem. Everything else seems to be checking fine
5th Gear
Sent the uecu off to module experts which turned out to be a huge scam. Learn from my mistake! May not end up getting the ecu back... Can I put an used one in or will I run into immobilizer problems?
Sorry for stepping into quicksand. I hope there's some resolution. I would try to get the original ECU back (I bet you have to pay for it, yes?)
A quick search for Module Experts reviews should have been a warning to stay away. ::shrug::
Replace the capacitors with only the ones referenced in this thread:
https://www.clublexus.com/forums/ls-...capacitor.html
Specified capacitors are cheap enough; don't buy Amazon or ebay caps. The sources below practice first in, first out and you're not getting ten year old components.
Capacitor sources:
https://www.mouser.com/
https://www.digikey.com/
https://www.newark.com/
Dezdez
02-03-20 12:25 PM
cpofwacotx
09-30-14 05:26 PM
