Speedo Cluster ls400 ucf20
To start from 80km/H means that the meter is biased -80km/H. It seems to me that the DA converter is biased negatively or the meter itself is biased. In order to find the root cause of it, you probably need good measuring tools and skills.
10th Gear
Does anyone have shcematics of these boards and cluster that would be greatly appreciated. Is rhe any way to test the actual wiring harness or is that issue out of the picture?
