98 LS400 ECU Swap
10th Gear
Inorder to swap ecus do I just plug the new ecu and it's key will work fine?
Will the remote lock and unlock work? Do I need to just buy the ecu and they key or are other components from the donor vehicle required for the swap?
My ecu is dead it's not fixable.
Thank you.
Thank you.
1998 ECU's have an immobilizer, it will need to be reprogrammed (or removed) before the replacement ECU will function.
https://www.google.com/search?q=ls40....clublexus.com
https://www.clublexus.com/forums/ls-...correct-2.html
The following 2 users liked this post by 400fanboy:
Homunculus (07-02-23),
Margate330 (06-30-23)
Thank you.
Thank you.
Incidentally who judged that your ECU is dead and not fixable?
The following 2 users liked this post by Yamae:
10th Gear
The remote lock/unlock is not controlled by the ECU. It is handled/controlled by the body and door computers. The immobilizer system is built in the ECU and you can't simply swap the ECU. The immobilizer chip is in the ECU and dealers/locksmith will re-write the stored data in it using a special tool and charge you some big money. Swapping only the chip is another simple way for DIYers who have good soldering skills. Some DIYers may re-write the data using a PC and a specially made interface circuit.
The ecu unfortunately didn't survive the capacitor change and some traces were melted 😭
I know that for 98-2000 a simple ecu swap wouldn't work, which is why I'm asking what parts I need from the donor vehicle other than the new ECU + it's key for full functionality.
Thank you so much for your help 🙏🙏
I don't know if the attachment will be of any help.
The question I would ask, what state is the replacement ECU in? Is it already in auto-registration mode?
Robnh
02-07-19 01:02 PM
