Diff part year - 1992 versus 1993, are they the same?
I recently traded for a 1992 LS 400. It has a welded diff, and I need to swap it out. I finally found a part online for the rear diff, and when I received it, it said it was a 1993 diff. Is there any difference between 1992 and 1993? Or am I good to go?
You are good to swap. 90-94 have the same differential mounting points. The only difference is the differential subframe bushings from 90-92 and 93-94.
You don't need to replace the bushings to make it work, it will bolt up just like the original one. I was just mentioning that difference between the model years.
You will have better luck overseas. I would try Amayama or Ebay. I do not recommend polyurethane bushings.
https://www.amayama.com/en/catalogs/...fferential-119
The mounting bush is indeed discontinued from new sources.
Your only chance is to go hunting for one from a junkyard or a parts car. Or worst case, a mystery bush from ebay.
