Type of coolant?
What do you mean by "from Autozone"? Existing coolant is from Autozone? or coolant that you plan on getting is from Autozone?
Toyota specifies P/N 00272-1LLAC-01 (diluted 50/50 with distilled water):
You can top off with this or an equivalent.
Stroock639 (07-09-23)
Do you know what's in there now?
Toyota specifies P/N 00272-1LLAC-01 (diluted 50/50 with distilled water): https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Hey, thanks for the reply. I don't know what's in there currently. Just looking at what I need to get to top off. Thank you.
Once topped up, check the coolant level for the next few weeks to make sure the level stabilizes and doesn't fall. You shouldn't be losing coolant.
You really can't go by the color of the existing coolant to determine what type of coolant is in the system. Simply because most aftermarket coolants are designed to mix with whatever color the existing coolant is. There is no standard for coolant coloring. Coolant chemistry is more important.
The attachments should be helpful when drain/refill becomes necessary.
Anyone have experience with Aisin ACT002 50/50 prediluted coolant? I noticed it at Rock Auto the other day and was curious as it was quite a bit less expensive than the Toyota branded coolant and it was Aisin branded.
https://priuschat.com/threads/aisin-coolant.198290/
looks to be the identical product, although toyota never officially 'approved' the premixed coolant... it also wasn't a thing yet lol
cj98ls (07-09-23)
