What part is this ontop of engine? Cause of evap codes?
Old 07-15-23, 12:31 AM
e30antonio
e30antonio's Avatar
Default What part is this ontop of engine? Cause of evap codes?
Hello, below are a few pictures of a plastic piece on the driver's side of the engine that has snapped off some time ago. It is a small box with and arrow on the top, right next to the engine hoist hook and oil cap. Note that I did try botching it together with gasket maker and a brass tube piece I found. It is also the reason for the metal hose clamp you see. Anyone know what part this is so I can replace it?
Also below is a screenshot of the current check engine light codes that I have. Would these be related to that broken piece?
Thanks.
Old 07-15-23, 07:17 AM
CLLEXUSS
CLLEXUSS's Avatar
When a car codes, more times than not its emissions related, that is certainly related to emissions.
Old 07-15-23, 07:30 AM
CLLEXUSS
CLLEXUSS's Avatar
Its the fuel vapor feed pipe. 2000 Lexus LS 400.
Old 07-15-23, 07:33 AM
CLLEXUSS
CLLEXUSS's Avatar
Cheap fix, I'd just buy one asap, you don't want to mess around with something that could be altering your fuel ratios confusing the computer.
Old 07-15-23, 08:40 AM
cj98ls
cj98ls's Avatar
Part # 23818-46110. Bell's got it for under $17. My '98 doesn't have this bit. Partsfan has a decent diagram, leads me to believe that it's a version of the EVAP system from 8-98 through the end of ls400 production.
edit - And evidently lived on into the ls430 years too. A good drawing as to how it's hooked up appears in the link that Bradland supplied at #3.
Old 07-15-23, 10:57 AM
400fanboy
400fanboy's Avatar
California? California cars have a unique ECU due to emissions. I think EGR\Air pump. Perhaps there is more equipment, I'm not sure. I'm not super familiar with the differences.
I mention so you can keep it in mind when diagnosing.
Old 07-15-23, 11:07 AM
bradland
bradland's Avatar
VSV Vacuum Switching Valve
THIS thread from the 430 side should tell you everything you need to know.
cj98ls (07-15-23)
Old 07-15-23, 01:01 PM
cj98ls
cj98ls's Avatar
Bradland, I think CLLEXUSS nailed it as the fuel vapor feed pipe. It connects into the VSV via a short tube but the plastic connector tube broke off the feed pipe and needs replacing. I wonder what's inside the plastic case?
Thanks for the link to the ls430 post on the VSV cleaning though. More stuff to do.
Old 07-15-23, 02:03 PM
bradland
bradland's Avatar
Yep, you're right I got my terms mixed up...🙃
It's just an empty plastic vessel. From what I understand it provides space for any vacuum inconsistencies (surges).
Old 07-17-23, 10:49 AM
timmy0tool
timmy0tool's Avatar
as everyone said, yes it's related to EVAP and will cause codes if it's open like that. it's pressurized and will sense a leak (small or large) when the VSV opens, throwing a CEL.
once you fix this and clear the code, you cannot just bring it to the smog shop directly. it will take a few drive cycles (at least 2) for the EVAP to "complete" before you can smog the car. ask me how i know!
Old 07-18-23, 06:46 PM
cj98ls
cj98ls's Avatar
So I drop in to the Cartune NZ YouTube channel and see that there's nothing new and decide to do a bit of browsing through the videos and look what I found!
It's a ls430 that he's working on, same EVAP System and VSV and black housing.
Sc30proje
Performance & Maintenance
10-29-22 08:19 PM
speedkar9
10-18-19 01:49 PM
ATC19
08-31-19 01:35 AM
Jeepdude
06-11-16 07:34 AM
cdvmagic
05-15-06 12:18 PM
Quick Reply: What part is this ontop of engine? Cause of evap codes?
