OBD1 not working
OBD1 not working
I have a 1994 LS400 and I just bought an Obd1 scanner with the correct plug for the car, but it will not communicate with the car. The scanner works, but the computer in the car won’t communicate with the scanner for some reason. I have yet to try the wire method but does anyone know possible reasons for it not communicating?
Read this; https://www.clublexus.com/forums/ls-...capacitor.html and you'll see all the other symptoms of it being bad.
Try the jumper wire method first and see if the car shows you the codes. It could just be that your scanner isn't really compatible with the car. What tool did you buy?
If that doesn't work, then consider checking the ECU
Simply check the ripple voltage explained in the FAQ page or check the inside of the ECU first. 29 years old is old enough for those QAS capacitors to leak. I worry that copper traces of ECU board are already eaten some by the leaked liquid which is now very strong alkali.
VolumeToo
11-22-17 05:32 PM
