Lifting the LS400 onto blocks
Looks like you have a lot of material outside to make more blocks.
Update: I got a set of Race Ramps 12" 2-section wheel cribs, which weigh about 3 lbs each
Now I don't exhaust myself lugging in the wood. With a Daytona long-reach low-profile jack, I can use the diff to get it up onto one 6" section each side at the rear, and then individually under the front sill jack points to get each front wheel up onto the same one section. I don't think I can use two sections with my current jack. (I can use the full 12" if I lower the car from the lift.)
I have the Arcan XL2T that's great. It has a 2 1/4" min height and a 24" max reach with a 2 ton capacity. Its heavy as hell but I only paid $150 for mine on OfferUp brand new.
deanbrown (02-23-24)
jimmycofc
04-13-14 01:21 PM
DIY LS400
05-10-08 03:02 AM
