LS400 fender question (UCF 10)
2nd gear
Hi so i’m looking at getting new fenders for my 1994 ls400 however i have ran into some issues finding the correct ones. On lexuspartsnow there is a fender that fits 1992-1994 but it is discontinued. However there is also a 1990-1993 available which doesn’t really make sense to me, i thought ucf10 is the same from 1990-1994 and why would the 1992-1994 fit when it says the 1990-1993 doesn’t fit. It doesnt make any sense to me so if someone could explain as to why it wouldnt fit would be very helpful. Ill include the links below
1992-1994 (sold out)
https://www.lexuspartsnow.com/parts/lexus-fender-sub-assy-front-lh~53802-50012.html
1990-1993
https://www.lexuspartsnow.com/parts/lexus-fender-sub-assy-front-lh~53802-50010.html
1990-1993
They are all the same part. Don't trust lexuspartsnow.com to give you an accurate listing as to what is available. I highly doubt that fender is still available new. If you're in Calgary give these guys a call
https://bodyshopsupplystore.ca/
Zovy (02-10-24)
There is one minor difference between 1990 and 1993 fenders for this car. The left fender has a buzzer mounted on the inside for the keyless entry system. The 1990-1992 fender has nothing for mounting that on the inside
Other than that, both panels are interchangeable
Also, new fenders are really really expensive. Why not get a used one? In either case you will probably need to paint it
Zovy (02-11-24)
2nd gear
so the 1990-1993 fender will fit a 94?
It will fit but as mentioned 1993-1994 left fenders are able to mount the keyless entry buzzer
So you will need to find a spot to mount that if you get a 1990-1992 fender.
If you want an exact fit, get a 1993-1994 panel
Body cladding and related brackets and clips will need to be transferred over
eddiej
08-29-09 04:33 AM
