Help: Moon roof and steering column stopped working
I have a 1999 LS 400 and the moon roof and the adjustable steering column stopped moving. I replaced the 15 amp # 6 fuse in the cabin but no luck. They are both on the same fuse which I find interesting. Any advice would be appreciated. Thanks
I replaced the 30 amp PWR and it didn't solve the problem. There are three 30 amp fuses in the diagram but I have only two installed. the middle slot is vacant. Should there be a third fuse there? Also I have had this car for four years and these issues never cropped up. Any suggestions would be appreciated.
A tilt/telescopic malfunction should set a DTC or DTC's but you need to access these with either the Toyota scan tool or one that will read Toyota manufacturer codes.
The attachment is of the DTC chart. Maybe the TDC's will help you narrow down where to look.
imperio
RX - 4th Gen (2016-2022)
04-07-23 01:16 PM
