96 LS 400 Misfiring multiple cyl when warm
4th Gear
Hi everybody
I just purchased a near mint 1996 LS 400 with 135k . The car runs and drives perfectly when cold but when it gets up to temp starts misfiring on cyl 1, 2, and 8. Codes PO300, P0301,PO302,PO308. Check engine light blinking and Tracs light blinking.
I'm going to start tearing into it in the next couple of day but have no experience with this engine and looking for advice on where to start.
Because the misfires occur on both banks I'm thinking it's not related to plugs,wires, cap and rotor but will probably just replace them as maintenance items anyways.
Could this be an ECU issue?
Any help would be appreciated.
Thanks
Thanks
Hi everybody
Thanks
Thanks
4th Gear
This is something that shouldn't be ignored. IIRC, the ECU sticky mentions that it's a not if, but when issue. You can "look" at other possible causes for the ignition issues but I wouldn't throw money and parts at it without solid confirmation that something other than the ECU is at fault.
Jim Walker aka the Lexpert does quick turnaround in my experience and will rebuild for $295 plus shipping. When I got my 1995 it was the first thing I did. He said one of the capacitors had just barely started to leak but otherwise we caught it in time which makes the job much easier. Generally I think better to go the rebuild route vs a new one unless you depend on the car and can’t have it out of service or your current one is beyond repair. It may be a good idea to pop yours open and have a look you just want to be cautious and careful.
I have definitely heard of ECU issues causing misfires. One guy on here I remember chased a misfire for a while and replaced a ton of parts before figuring out it was the ECU. Regardless, you definitely need to get the ECU fixed before there is any more damage (as it is, I would send comprehensive pictures to any repair shop before mailing to make sure they don’t think it’s a write off). You have at least one actively leaking capacitor so time to address that ECU ASAP. The longer it leaks the harder it is to fix until it gets to a point where it possibly can’t be fixed
Please read through this link before sending off your ECU for repairs or replacements. Quality components are as important as the work.
https://www.clublexus.com/forums/ls-...capacitor.html
It is one of typical failing capacitor problems to have "The Misfiring multiple cylinders when warm". You definitely need to refurbish the ECU. I worry that traces are already damaged and those also should be fixed. Hope the damage is only the surface.
