Front wheel bearings and hubs replacement- 2000 LS400
Hi all,
I need my front wheel bearings replaced and I'm thinking of replacing the hubs as well for the heck of it. I am capable of taking the spindles/knuckles off the car, but I don't think I'd be able to pull out the old bearings and pop in the new bearings by hand. So, I was thinking of taking both of the entire spindle assemblies to a shop, along with new bearings and hubs, and letting them replace the parts.
My main question is, what is the parts list that I'd need to supply a shop with to replace the bearings and hubs? I see the bearings on RockAuto, but the hubs seem hard to find. Are these the only two parts needed?
Why replace it? I don't think there is any reason to replace the hub or knuckle. I think you just press the new bearing in. I'm not sure if you need to replace other parts like the snap ring (probably).
Here's a vid on the process
And parts
https://www.amayama.com/en/catalogs/...t-axle-hub-127
And parts
Hi all,
The hub should only be replaced if it's damaged. Def don't buy a hub from RA get a Toyota part.
The NSK bearing at RA is an excellent choice if you dont want to pay dealer prices.
Bearing
Seal
Snap ring
Axle nut
Cap (Not in Pic)
coachstu
GX - 1st Gen (2003-2009)
11-02-20 08:41 PM
