running rich and misfire
2nd gear
I recently purchased a 95 LS400 with 240k miles and it started misfiring, with smoke coming out the exhaust and it would reek like gas. The codes I get are for misfires in cylinder 2, 3, 4, 6, and 8 as well as P0170. I replaced the fuel injectors with junkyard ones (cleaned them while tapping them with power) thinking it was that and didn't solve the issue. Then I put a new fuel regulator and it gave it a bit more power and way less fuel was burning into the exhaust. The regulator was toast I could hear the spring move around when you shake it. I put new plug wires, checked for spark to see if all the coils where good and they all got spark. I haven't done plugs yet but that was my next guess was either plugs, O2 sensors, or the fuel dampener or fuel filter. At some point oil change maybe as well since fuel might have thinned out my oil but does anyone else have an idea to what it could be? It is running very rich and smells like fuel into the cabin still but not as bad as it was before I swapped out the regulator.
2nd gear
No it has not but, it doesn't have symptoms of a bad ECU. A friend was telling me it could be the vacuum switch valve could be bad causing the regulator to go bad.
Actually 400fanboy is correct, the P0170 code is a possible symptom of an issue with an ecu. But you need proper diagnostics, or continue on with process of elimination, entirely up to you.
Did someone delete my post?
scpoehl
06-23-23 07:11 PM
97trophy
IS - 1st Gen (2001-2005)
01-30-21 04:06 AM
